Elastic Audio : Elastic Properties Window
Clip Property
Source Length Property (Tick-Based Tracks Only)
Source Tempo Property (Tick-Based Tracks Only)
Meter Field (Tick-Based Only)
TCE Factor Property
Event Sensitivity Property
Reset Button
Input Gain Property
Pitch Shift Property (Polyphonic, Rhythmic, and X-Form Only)
The Elastic Properties window displays information about Elastic Audio processing and analysis for one or more clips. You can also use the Elastic Properties window to adjust Elastic Audio processing and analysis data.
There are different Elastic Properties available in the Elastic Properties window, depending on whether the track is tick-based or sample-based. If the track is sample-based, a reduced set of Elastic Audio Properties are displayed.
Elastic Properties, tick-based
Elastic Properties, sample-based
