Meter Field (Tick-Based Only)
Elastic Audio analysis does not calculate meter and assumes all files are in 4/4. If you work with meters other than 4/4, use the Meter property to correctly identify the source meter.
To change Meter of a clip:
1. Open the Elastic Properties window for the clip.
2. Click in the Meter nominator field and type the correct number of beats per measure. For example, if the clip is in 3/4, type 3.
3. Click the Meter denominator field and type the correct note value. For example, if the meter is in 6/8, type 8.
