Source Tempo Property (Tick-Based Tracks Only)
The Source Tempo property in the Elastic Properties window displays the average tempo of the source file, which is calculated based on the detected transient events and the length of the file. If the tempo of the source file was analyzed incorrectly, you can change it.
To change Source Tempo of a clip:
1. Open the Elastic Properties window for the clip.
2. Select the correct note value for the beat from the Tempo Resolution pop-up menu. For example, if the source file is in 5/8, select 1/8 note.
3. Do one of the following:
Type the tempo in the Source Tempo field.
If the tempo was incorrectly analyzed as being half the tempo of the source file, click the
x2 button.
If the tempo was incorrectly analyzed as being twice the tempo of the source file, click the
1/2 button.
