Elastic Audio : Elastic Properties Window : Source Length Property (Tick-Based Tracks Only)
The Source Length property in the Elastic Properties window displays the length of the clip based on the source file in bars and beats. If the length of the source file was analyzed incorrectly, you can change it.
To change the Source Length of a clip:
1. Open the Elastic Properties window for the clip.
2. Do one of the following:
*Type the correct bar, beat, and tick values in the Source Length field.
*If the duration was incorrectly analyzed as being half the duration of the source file, click the x2 button.
*If the duration was incorrectly analyzed as being twice the duration of the source file, click the 1/2 button.
*Changing the duration of a clip on an Elastic Audio-enabled track using the TCE Trim tool updates the Source Length in the Elastic Properties window.
