Workspace : Column Data
Column Data
Comments Fields
Adding and Editing Comments
In Workspace browsers, each row of data represents an item in a database (such as a file, project, or volume). Each column displays specific data for an item.
• Name
Displays the name of the file, folder, volume, catalog, or project. For offline items, the name is italicized.
• Permissions
Displays the designated permissions for volumes for media recording, playback, or transfer only.
*For more information, see “Volume Permissions” on page 123.
• Kind
Displays whether the volume, folder, catalog, or file. For files, this column displays what kind of file it is: audio file or other. This field cannot be edited. For audio files, this column also indicates whether the file is sample-based to tick-based.
• Size
Displays the size of a file. This field cannot be edited.
• Waveform
Displays a graphical overview of an audio file. See “Waveforms” on page 147 for more information.
• Duration
Displays the duration of a file in absolute time (minutes and seconds), regardless of the timecode format. For clip groups, MIDI, tick-based Elastic Audio files, REX, and ACID files, Duration displays Bars and Beats. This field cannot be edited.
• Date Indexed
Displays the last indexed date for the item. This field cannot be edited.
• Capacity
Displays the total capacity of a volume. This field cannot be edited.
• Free
Displays the unused space on volumes. This field cannot be edited.
• File Comment
Displays any embedded comments associated with the file. File comments are supported with BWF files, but are not supported with AIFF files. File Comments always remain with the file when copied, converted, or transferred. See “Comments Fields” on page 137for more information.
• Database Comment
Displays user comments stored with the database, with support for Finder comments. See “Comments Fields” on page 137for more information.
• Date Modified
Displays the last modified date for the item. This field cannot be edited.
• Date Created
Displays the creation date of an item. This field cannot be edited.
• Number of Channels
Displays the number of channels in an audio file: mono, stereo, or 3–8 as appropriate for supported multichannel files. This field cannot be edited.
• Format
Displays the audio file format: WAV, WAV (ACID) for ACID files, WAV (BWF), AIFF, MP3, or ReCycle for REX files. This field cannot be edited.
• Sample Rate
Displays an audio file’s sample rate. This field can be edited in Workspace browsers for WAV and SD II files only. This can be useful when dealing with audio that has been pulled up or down, or to force a sample rate conversion to occur if that is necessary before importing a file that otherwise would not require conversion.
• Bit Depth
Displays an audio file’s bit depth. This field cannot be edited.
• Tempo
Displays the tempo associated with clip group, MIDI, tick-based Elastic Audio files, REX, and ACID files. This field cannot be edited.
• Video Compression
Displays the compression ratio of video files where applicable.
• Frame Rate
Displays the frame rate of video files where applicable.
• Original Time Stamp
Displays the original time stamp (timecode location) of audio or video files.
• User Time Stamp
Displays the user time stamp, if any, of audio files only.
• Path
Displays the directory path to the item.
• Unique ID
Displays the unique ID for a Pro Tools file.
• Clip Name
Displays the name of the file, or the Avid clip name when the item is an AAF or OMF file. The Clip Name is what appears in the Timeline and Clips List when a file is imported into a project.
• Tape
This column displays the original Avid tape name if the item is an OMF file (audio or video). If an audio file was originally recorded in Pro Tools, this field displays the name of the original project.
• TC Rate
This column displays the frame rate of the item if the item is an AAF sequence or an OMF sequence or file: 24, 25, 29.97, 30, drop or non-drop. For sequences, the frame rate at the start of the sequence is displayed.
• Channel Names
Displays the channel name and number data embedded in multichannel audio files. You can edit the Channel name for mono BWF files only. When editing the channel name, anything entered in parentheses is discarded. However, the channel number will always be preserved.
• Scene
Displays scene number data embedded in audio files.
• Take
Displays take number data embedded in audio files.
• Shoot Date
Displays origination date and time information embedded in audio files. However, many field recorders do not populate the Shoot Date field, relying instead on the file’s Creation Date to indicate date of production. When Pro Tools imports a field recorder file, it checks to see if the Shoot Date field is populated. If it is empty, Pro Tools copies the Creation Date of the original source file to the Shoot Date field of the new imported files. This field cannot be edited.
• Sound Roll
Displays sound roll number data (This data is usually named “Tape” in BWF files, but is distinct from the date displayed in the Workspace Tape column). This field cannot be edited.
• Sound Roll TC
Displays the starting timecode of audio files. This field cannot be edited.
• Sound Roll TC Rate
Displays the frame rate information embedded in audio files: 24, 25, 29.97, 30, drop or non-drop. This field cannot be edited.
• User Bits
Displays text information embedded in audio files. This field can be used for user comments, or auto-generated info with certain field recorders.
• Tape ID
Displays tape ID information embedded in audio files. This field cannot be edited.
• Project
Displays the project name data embedded in audio files.
• Circled
Indicates if the status of a take is set to “circled” (No or Yes) in audio files. This is usually for indicating which take should be used.
• Plug-In Name
Displays the name of the plug-in for Plug-In Settings files (.tfx).
• Plug-In Manufacturer Name
Displays the plug-in manufacturer’s name for Plug-In Settings files (.tfx).
• Link Path
Displays the path to the file used for relinking. Available in the Relink window only.
