MIDI Recording : Recording Audio from a MIDI Instrument
Recording Audio from an Instrument Plug-In
Recording Audio from an External MIDI Instrument
Typically, you will monitor the audio from MIDI instruments (both hardware and plug-ins) using Instrument and Auxiliary Input tracks. During the final mixdown, audio from Instrument and Auxiliary Input tracks can be included when using the Export Audio Mix command, or on a bussed recording path if recording to a new track.
*When using instrument plug-ins, you may want to record the audio from a MIDI instrument to a new track before mixing in order to free up processing resources.
