MIDI Recording : Recording Audio from a MIDI Instrument : Recording Audio from an External MIDI Instrument
You can record audio from an external MIDI instrument in one of two ways:
• By bussing audio from the output of the Instrument (or Auxiliary Input) track used to monitor the MIDI instrument to an audio track for recording.
• By setting the audio track’s Audio Input Path selector to the same Audio Input Path as the Instrument (or Auxiliary Input) track used for monitoring the external MIDI instrument.
This second method avoids any additional latency associated with bussing. However, be sure to mute the Instrument (or Auxiliary Input) track used for monitoring while recording the same audio path to the audio track.
