Plug-In Inserts : Plug-In Settings Dialog : Selecting Plug-In Presets from the Plug-In Selector
Pro Tools lets you select plug-in settings from the Insert Right-click menu using the User Presets submenu.
To select a plug-in setting for a plug-in insert in the Mix or Edit window:
1. With Inserts view shown, Right-click the plug‑in Insert in the Mix or Edit window.
2. From the User Presets submenu, select the plug-in setting you want.
