Dragging and Dropping Plug-In Settings Files
You can insert a plug-in with a specific plug-in settings file, as well as change plug-in settings of inserted plug-ins by dragging and dropping plug-in settings files from a Workspace browser.
To insert a plug-in by drag and drop:
Drag a plug-in settings file from a Workspace browser to an Insert in the Mix (or Edit) window.
To change a plug-in preset by drag and drop:
Drag a plug-in settings file from a Workspace browser to the plug-in window. The plug-in settings file must be for the same plug-in name. For example, you cannot replace a 1-Band EQ 3 with a plug-in setting for 4-Band EQ 3.
