Auditioning Plug-In Presets
When the Plug-In Settings dialog is open, you can have Pro Tools | First automatically scroll through and audition the plug-in settings files saved in the plug-in’s root settings folder.
To audition plug-in presets:
1. Click the Settings Select button.
2. From the dialog list, click a preset—the starting point from which you will scroll through the settings files.
3. Enter a value for the number of seconds that will elapse between each preset change.
4. Select the Increment Setting option.
After the specified number of seconds, Pro Tools selects the next preset.
5. When you are finished auditioning presets, do one of the following:
Click
Done to stop incrementing patches, and to close the Plug-In Settings dialog.
Deselect the
Increment Patch option to stop incrementing patches and keep the Plug-In Settings dialog open. Then select the preset you want and click
Done.
