Managing Presets
Use the Plug-In Settings menu to manage plug-in presets.
To save a preset:
1. Choose Save Settings from the Plug-In Settings menu.
2. Type a name and click OK. The setting appears in the Plug-In Librarian menu.
Press Command+Shift+S (Mac) or Control+Shift+S (Windows) to save plug-in settings.
To load a plug-in preset:
Choose the name of the preset from the Plug‑In Librarian menu.
To import a preset:
1. Choose Import Settings from the Plug-In Settings menu.
2. Locate the settings file you want to import and click Open. Pro Tools | First loads the setting and copies it to the root destination folder.
To copy plug-in settings:
Choose
Copy Settings from the Plug-In Settings menu.
Press Command+Shift+C (Mac) or Control+Shift+C (Windows) to copy plug-in settings.
To paste plug-in settings:
1. Open the destination plug-in.
2. Choose Paste Settings from the Plug-In Settings menu.
Press Command+Shift+V (Mac) or Control+Shift+V (Windows) to paste plug-in settings.
To create a custom User Default preset:
1. Create and save a plug-in settings file.
2. Select Set As User Default from the Plug-In Settings menu.
To make a plug-in default to your custom preset:
From the Plug-In Settings menu, select Settings
Preferences > Set Plug-In Default To > User Setting.
