Plug-In Inserts : Plug-In Windows : Preset Controls in the Plug-In Window
Preset controls in the plug-in window
• Plug-In Settings Menu
Lets you copy, paste, save, and import plug-in settings.
• Plug-In Librarian Menu
Recalls plug-in presets (plug-in settings files saved in the plug-in’s root settings folder). “Plug-In Presets” on page 646.
• Next (+) and Previous (–) Setting Buttons
Let you select the next or previous preset from the Librarian menu.
*You will lose the current settings if they are not saved before you use the Next and Previous Setting buttons. Always save your plug-in settings as a preset using the Plug-In Settings menu.
• Plug-In Settings Select Button
Accesses the Plug-In Settings dialog, which lists the presets for the selected plug-in. From this list, you can audition and select plug-in presets.
• Compare
Toggles between the original saved plug-in settings and any changes you have made to it so you can compare them.
