Making Selections : Selecting Track Material : Using the Edit Selection Indicators (Start, End, and Length) : Calculator Entry Mode
You can perform calculator-style editing of values in the Edit Selection indicators.
To subtract time values:
1. In the Edit Selection indicator, highlight the time field you want to change.
2. Press Minus (–) on the numeric keypad.
3. Type the amount you want to subtract from the current time value, then press Enter.
4. Press Enter again to apply the change.
To add time values:
2. Press Plus (+) on the numeric keypad.
3. Type the amount you want to add to the current time value, then press Enter.
