Making Selections : Selecting Track Material : Using the Edit Selection Indicators (Start, End, and Length) : Numeric Entry Shortcuts for Selection Indicators
You can use the following shortcuts for entering values in the Edit Selection indicators:
• Press the Forward Slash (/) key to cycle through the three Edit Selection indicators.
• Use Period (.) or the Left and Right Arrow keys to move through the different time fields in each Edit Selection indicator.
• Press the Up or Down Arrow keys to increase or decrease numerical values.
• Move the mouse scroll wheel up or down to increase or decrease numerical values.
• Drag in a field to scroll to a new value. For finer resolution, Command-drag (Mac) or Control-drag (Windows).
• Press Command (Mac) or Control (Windows) and Plus (+) or Minus (–), then type a number, to add or subtract from the current field value. For example, to add 10 to a current field value, press Command (Mac) or Control (Windows) and Plus (+) key, type “10,” and press Enter.
• Press Escape to exit the Edit Selection indicators without entering any values.
*These shortcuts can also be used to enter start and end values in the Transport window.
