Two Main Module Types:
CM416 moduleModules connect to DSP core via ethernet.
4 Control Surface Combinations
(other combinations are possible):Surface 1 - 16 channel strips - *width 48.6" (1,234.5mm)
Surface 2 - 32 channel strips - *width 72.9" (1,851.7mm)
Surface 3 - 48 channel strips - *width 97.2" (2,468.9mm)
Surface 4 - 48 channel strips with blanks - *width 121.5" (3,086.1mm)
* All widths include 1" per side for end caps. Subtract 2" (50.8mm) for system without end caps.
[click for pdf showing further dimension info]
