Modular Input/Output
Max Air can have as many inputs and outputs as needed simply by adding modular I/O. Configure Max Air to the studio's exact I/O requirements.
Avid can supply a range of multi-channel high quality analog and AES converters that convert to multi-channel (up to 56 channels at 48KHz) MADI for connection to the Max Air DSP core.
- MADI to Analog, Analog to MADI
- AES/EBU to MADI, MADI to AES/EBU
- Remote Mic Preamplifiers to AES/EBU (use as AES/EBU converter to get to MADI)
- The FC726 is a bi-directional digital format converter with built in sample rate conversion that connects the DSP Core to the digital world via AES/EBU, MADI, SDIF2, Pro Digi, TDIF and ADAT.
