Pro Tools | First Projects : Opening a Project : Opening a Project that Contains Unavailable Resources
Pro Tools | First prompts you when opening a project that contains unavailable I/O paths or plug-ins. This is common when opening projects on different systems.
The Unavailable Resources dialog provides an initial report of the missing components. To save a text (.txt) file containing a more detailed Notes report, along with the resulting action, click Yes. The Notes report is named with the project name, followed by Notes.txt. You can choose to save this file to any location.
The following occurs when opening a project with unavailable items:
• Inserts assigned to unavailable plug-ins are made inactive.
• Inputs, outputs, and sends that are assigned to unavailable paths are made inactive.
