Changing Presets with the Next (+) and Previous (–) Setting Buttons
These buttons let you select the next or previous preset in the Plug-In Librarian menu.
To change plug-in presets using the +/– buttons:
Click the Plus (+) or Minus (–) buttons to select the next or previous preset. The next (or previous) preset is enabled, and the Plug-In Librarian menu changes to show the name of the new preset.
You will lose the current plug-in settings if they are not saved before you use the Next and Previous Setting buttons. Always save your plug-in settings to the selected Root Settings folder.
