Plug-In Inserts : Plug-In Presets : Settings Preferences
The Settings Preferences submenu provides commands for configuring preferences for saving and importing presets. They include:
• Set Plug-In Default To
Sets the default preset to either Factory Default (the standard default setting for that plug-in) or User Default (your custom setting).
• Save Plug-In Settings To
Selects the folder where presets (plug-in settings files) are saved. If you select Root Settings Folder, the settings are saved in the folder you specified with the Set Root Settings Folder command.
*To save plug-in settings to any location other than the default Plug-In Settings folder, you must first create a folder named “Plug-In Settings” in the new location and then save to that folder.
