Basic Mixing : Audio Input and Output Paths : Display of Multiple Output Assignments
When a track is assigned to multiple output paths, the Output Path selector denotes multiple assignment status and active/inactive status with the following indicators:
• A plus sign (+) indicates that the track has multiple output assignments.
Indication of multiple output assignments
• In the Output Path selector menu, all currently assigned track outputs are checked to indicate they are active for the current track.
• An asterisk (*) indicates that one or more currently assigned outputs is Inactive.
Indication of multiple output assignments with at least one inactive output
