Basic Mixing : Audio Input and Output Paths
Input Audio Path
Output Audio Path
Output Windows
Multiple Output Assignments
Display of Multiple Output Assignments
About the “No Output” Option
Pro Tools lets you configure the physical input and outputs of your audio interfaces and also internal bus paths and subpaths in the I/O Setup dialog and the Hardware Setup dialog. These hardware inputs and outputs, and internal bus paths can be assigned as inputs and outputs on audio, Auxiliary Input, Instrument, and Master Fader tracks.
