Template Mapping for Unequal Meters
In cases where the Groove Templates and track selections are based on different meters, the template will be repeated or truncated to match the number of beats in the selection.
For example, if the Groove Template contains fewer beats than the selection, such as a one-bar template in 6/8 being applied to a one-bar selection in 4/4, the template repeats to make up the difference.
Applying a 1-bar groove template in 6/8 to a 1-bar selection in 4/4
If the Groove Template contains more beats than the selection on a track, such as a one-bar template in 6/4 being applied to a two-bar selection in 4/4, only uses the appropriate number of beats.
Applying a 1-bar groove template in 6/4 to a 1-bar selection in 4/4
