Event Operations : Groove Quantize : Recalling Options Slider Settings
To Save the groove template with the current Options Slider Settings:
1. In the Quantize window, select Recall with Template if you want to restore all Groove Quantize Options to the settings that are saved with the current template
2. Click the Save button.
3. Enter or edit any comments you want to save with the template.
4. Do one of the following:
*Click the Save button to save the groove template with the current Options Slider Settings.
*Click the Save As button to make a copy of the groove template with the current Options Slider Settings. In the resulting Save dialog, enter a name for the copy and click Save.
Slider settings can be lost if any of the following operations are performed without saving the settings first:
• Another Event Operations window is selected.
• The Event Operations window is closed.
• You switch to another groove template.
