AudioSuite Processing : AudioSuite Window Header : Selection Reference : AudioSuite Processing Clip Groups in the Clips List
AudioSuite plug-ins process Clip Groups in the Clips List with certain limitations. With audio files, AudioSuite processes are applied to all copies of a unique audio file in your project when the Clips List option and the Use in Playlist option are selected. However, when a Clip Group is selected for Audio Suite processing in the Clips List, Pro Tools does not recognize the Clip Group as audio. This is because a Clip Group is not treated as audio until it is actually used in a track. To apply AudioSuite processing to a Clip Group in the Clips List, first ungroup the Clip Group, and then regroup it after processing.
To apply an AudioSuite process to all copies of a Clip Group in a project at once:
1. Select the Clip Group to be processed.
2. From the Clip menu, select Ungroup All. All elements of the group will remain selected.
3. Perform the AudioSuite processing.
4. From the Clip menu, select Regroup.
When prompted, choose Modify to apply the AudioSuite process to all copies of the Clip Group in the project, or Copy to apply it only to the selected Clip Group.
