MIDI Editing : MIDI Event List : MIDI Event List Options
The MIDI Event List menu provides the following options:
• Show Sub Counter
Displays event times in the Sub Time Scale.
• Go To
Opens the Go To dialog, where you can specify a location, based on any of the supported Time Scales, to which the Edit insertion point is moved.
• Scroll To Edit Selection
Scrolls the MIDI Event List to the Edit start point or Edit insertion point.
• Page Scroll During Playback
Scrolls the MIDI Event List during playback.
• Show Note Length
Displays note lengths, instead of note end times, in the Length/Info column of the MIDI Event List.
• Show Note End Time
Displays note end times, instead of note lengths, in the Length/Info column of the MIDI Event List.
• Insert
Provides a submenu of options that let you insert any type of MIDI event.
• Insert At Edit Location
Defaults the location for inserted events defaults to the Edit start point or Edit insertion point.
• Insert At Playback Location
Lets you insert events in the MIDI Event List in real time while listening to the project playback.
• Insert At Playback Location With Grid
Snaps the location for events inserted in real time to the grid.
• View Filter
Opens the View Filter dialog, where you can specify which events are displayed in the MIDI Event List (see “View Filter for MIDI Event List” on page 421).
