Inserting Another Event
After inserting an event, you can easily insert another event of the same type. The event type to be inserted is indicated at the bottom of the Insert menu.
Example: After inserting a note, to insert another, do one of the following:
From the MIDI Event List menu, select
Insert > Another Note.
With the MIDI Event List as the front-most window, press Command+M (Mac) or Control+M (Windows) to Insert a note.
When the option for Insert At Playback Location is enabled (see “MIDI Event List Options” on page 727), you can use the keyboard shortcuts for inserting “another” event to insert events on-the-fly.
