MIDI Editing : Real-Time Properties Settings : Duration : Duration Mode Pop-Up Menu
Select one of the following options from the Duration Mode pop-up menu: Set, Add, Subtract, Scale, Legato/Gap, or Legato/Overlap.
• Set
Select to set notes to the specified duration.
• Add
Select to add the specified duration to the current duration of each note.
• Subtract
Select to subtract the specified duration from the current duration of each note.
• Scale
Select to scale the current duration of each note by a percentage from 1 to 400%.
• Legato/Gap
Select to extend each note to the following note. The specified duration is the subtracted to create a consistent gap between notes.
• Legato/Overlap
Select to extend each note to the following note. The specified duration is then added to create a consistent amount of overlap.
