MIDI Editing : Real-Time Properties Settings
Quantize
Duration
Quantize
Quantize either can be based on a grid or a groove template. For grid quantize, additional tuplet and grid offset settings are available in addition to the standard MIDI quantize properties. For groove quantize, additional controls are provided to set the extent to which the groove’s duration and velocities are applied. Both grid and groove quantize also let you set a strength amount, an “include” range, and a randomize amount
*Quantize cannot be applied as a Real-Time Property to MIDI Input.
• Quantize Pop-Up Menu
Select the quantize value, including all standard note rhythm values between whole notes and 64th notes, including dotted and triplet options. This pop-up menu also provides access to all standard groove templates.
• Swing Value
Enter the amount of swing as a percentage between 0 and 300%.
• Tuplet Value
Enable Tuplet and enter the ratio for the tuplet (1–99), such as 3 to 2 or 5 to 4. Tuplet is only available in the expanded Real-Time Properties window.
• Offset Value
Enable Offset and enter the offset value in Ticks between –2000 and 2000. Offset is only available in the expanded Real-Time Properties window.
• Strength Value
Enable Strength and enter the amount as a percentage between 0 and 100%. Strength is only available in the expanded Real-Time Properties window.
• Include
Enable Include and enter the range between 0 and 100%. Include is only available in the expanded Real-Time Properties window.
• Random
Enable Random and enter a percentage between 0 and 100%. Random is only available in the expanded Real-Time Properties window.
