MIDI Editing : MIDI Real-Time Properties : Enabling Real-Time Properties
To enable Real-Time Properties:
1. Select a track, or make an Edit selection.
2. In Real-Time Properties view in the Edit window, or in the Real-Time Properties window, select Real-Time Properties by clicking the property name (Quantize, Duration, Delay, Velocity, or Transpose). Enabled Real-Time Properties are highlighted and display their settings.
3. If you are using the Real-Time Properties window and Link Track and Edit Selection mode is enabled, select the track or clip to affect from the Apply To pop-up menu.
4. Configure the Real-Time Properties settings (see “Real-Time Properties Settings” on page 408).
Enabled Real-Time Properties are heard on playback and play through for the selected tracks and clips.
