MIDI Editing : Note and Controller Chasing
Note Chasing
Controller and Program Chasing
Default Controller Values and Chasing
Note Chasing
Note Chasing allows long, sustained MIDI notes to be heard when playing from a point after their start time. For example, if a note’s start time is at 1|1|000 and lasts for 8 measures (until 9|1|000), note chasing lets you begin playing from bar 5 and still hear the note that started at 1|1|000 as it continues to sustain until 9|1|000.
Note Chasing is an option that can turned on and off individually for each MIDI or Instrument track. By default, new MIDI and Instrument tracks have Note Chasing enabled.
To enable Note Chasing for a MIDI track:
*Click the track’s MIDI Behavior selector and select the Note Chasing option.
Note Chasing enabled for a MIDI track
Make sure to disable Note Chasing when working with samplers that are playing loops. If a MIDI track, for example, is triggering a 4-bar drum loop and you begin playing at bar 3, the loop will begin playing at the wrong time and be out of synchronization with the other tracks.
