MIDI Editing : Patch Select (Program and Bank Changes) : MIDI Patch Names
MIDI Patch Names
Pro Tools supports XML (Extensible Markup Language) for storing and importing patch names for external MIDI devices (such as MIDI instruments). Pro Tools installs MIDI patch name files (.midnam) for the factory default patch names of many common MIDI devices.
*MIDI patch name files (.midnam) can be edited in any text editor, or you can use third-party patch librarian and editor software to create your own custom patch names.
On Mac, these files reside in /Library/Audio/MIDI Patch Names/Avid.
On Windows, these files reside in Program Files\ Common Files\Avid\Pro Tools\MIDI Patch Names\.
To import MIDI patch names into Pro Tools:
1. Choose Setup > MIDI > MIDI Studio.
2. Do one of the following depending on your computer platform:
*On Mac, verify the MIDI Device name in the MIDI Studio window (see “MIDI Studio Setup (Mac)” on page 34).
*On Windows, verify the MIDI Device name in the MIDI Studio Setup window (see “MIDI Studio Setup (Windows)” on page 37).
*For information on configuring MIDI on Windows and Mac systems, see “Configuring MIDI” on page 34.
3. Verify the Instrument or MIDI track output is correctly assigned to the MIDI device.
4. Click the Instrument or MIDI track Patch Select button.
Patch Select button, Edit window
Patch Select button, Mix window
5. In the Patch Select dialog, click Change.
Patch Select dialog
6. In the Open dialog, do one of the following:
*On Mac, navigate to /Library/Audio/MIDI Patch Names/Avid/<name of manufacturer>, and select the MIDI Patch Name file (.midnam) for the MIDI device.
*On Windows, navigate to Program Files\Common Files\Avid\Pro Tools\MIDI Patch Names\<name of manufacturer>, and select the MIDI Patch Name file (.midnam) for the MIDI device.
7. Select the MIDI Patch Name file (.midnam) for the MIDI device.
8. Click Open. The Patch Select dialog is populated by patch names from the selected file.
Patch Select dialog with patch names
9. For MIDI devices that have multiple banks of patches, select which bank of patches you want from the Bank pop-up menu.
Choosing a bank in Patch Select dialog
Once patch names have been imported into Pro Tools, they are available for that MIDI device in all projects.
To clear patch names:
1. In the Patch Select dialog, click the Clear button.
2. Click Done.
