Using the Time Compression/Expansion Trim Tool in Shuffle Mode
In Shuffle mode, the trimmed clip will always begin at the original clip’s start point regardless of whether you trim from the front to the rear or from the rear to the front.
To compress or expand MIDI clips in Shuffle mode:
1. Set the Edit mode to Shuffle.
2. Set the MIDI or Instrument track to Clips view.
3. Select TCE Trim tool.
4. With the Time Compression/Expansion Trim tool, drag the MIDI clip’s start or end point to compress or expand the clip freely. A new MIDI clip is automatically created, and appears both in the track and in the Clips List.
