Arranging Clips : Shuffling Clips
Shuffling Clips
Shuffling Multiple Tracks and Multichannel Clips
In Shuffle mode, you can move clips freely within a track or onto another track, but their movement is constrained by other clips. That is, if you place several clips in a track, their start and end points automatically snap to each other. You can then “shuffle” their order, but you cannot separate them from each other and you cannot make them overlap as in Slip mode. In Shuffle mode, adding another clip to the beginning of a track moves all subsequent clips to the right by the length of the clip added.
To shuffle clips:
1. Enable Shuffle mode (see “Edit Modes” on page 284).
2. Drag a mono clip from the Clips List to an empty track. The clip snaps to the beginning of the track.
3. Drag a second clip from the Clips List to the same track, somewhere in the middle. The start point for the second clip snaps to the end of the first clip.
4. With the Grabber tool, drag the second clip to the beginning of the track.
Pro Tools “shuffles” the position of the two clips. The second clip now occurs first, yet the two still cling together.
5. Experiment more with Shuffle mode by dragging additional clips to the track and rearranging them.
If you place a clip while in Slip mode and switch to Shuffle mode, Pro Tools preserves the relative timing and position of the slipped clip, and any space between it and other clips.
*With certain workflows, it is important to exclude Shuffle mode in order to ensure that clips stay time-aligned while editing. Shuffle Lock prevents you from inadvertently entering Shuffle mode by disabling all key commands for Shuffle mode. For more information, see “Shuffle Lock” on page 285.
