Memory Locations : Memory Locations Commands and Options
View Filter Icons
Color and Properties
You can select viewing and sorting options, along with commands for creating and removing Memory Locations, from the Memory Locations Window menu.
• View Filter Submenu
Provides commands to show or hide specific memory location properties:
- Show Icons
- View Markers
- View Selections
- View Locations with Zoom Info
- View Locations with Pre/Post Roll Info
- View Locations with Track Height Info
- Show Markers Only
- View All
• Show Main Counter
When selected, a column appears in the Memory Locations window that displays the locations based on the Main Time-scale for Markers, and the start times for Selection Memory Locations. General Property Memory Locations display nothing in this column.
You can click at the top of the Main Time Scale column for a pop-up menu that lets you change the Main Time Scale.
• Show Sub Counter
When selected, a column appears in the Memory Locations window that displays the locations based on the Sub Time Scale for Markers, and the start times for Selection Memory Locations. General Property Memory Locations display nothing in this column.
You can click at the top of the Sub Time Scale column for a pop-up menu that lets you change the Sub Time Scale.
• Show Comments
When selected, a column appears in the Memory Locations window that displays the comments for each of the Markers.
• Sort by Time
When selected, Markers are sorted by their order in the Timeline, followed by Selection and General Properties Memory Locations, which are listed in the order in which they were created.
When Sort by Time is deselected, all Memory Locations are listed in the order of their assigned numbers.
• New Memory Location
Choose this command to create a new Memory Location.
• Edit <Name>
Opens the Edit Memory Location dialog for the selected Memory Location. You can also double-click a Memory Location in the Memory Locations window to edit it.
• Clear <Name>
Clears the selected Memory Location, but does not remove its slot. Subsequent Memory Locations are not renumbered.
*Option-click (Mac) or Alt-click (Windows) a Memory Location in the Memory Locations window to clear it.
• Delete All
Deletes all Memory Locations. The next Memory Location you add starts at slot number 1.
• Insert Slot Before <Name>
Adds a new, empty Memory Location slot above the selected Memory Location, and renumbers all subsequent Memory Locations.
• Delete <Name> Slot
Deletes the selected Memory Location, and renumbers all subsequent Memory Locations.
• Default To Marker
When selected, new Memory Locations default to Markers, though in the New Memory Location dialog you can still define the new Memory Location as one of the other types.
• Auto-Name Memory Location
When selected, Memory Locations are created automatically without encountering the New Memory Location dialog. If the Default To Marker option is selected, a Marker Memory Location is auto-created. Otherwise, the Memory Location type is determined by whatever type (Marker, Selection, or None) was created last.
