Control Surface
S5 Fusion includes the System 5 control surface with a new
look charcoal finish complete with 8 to 56 channel strips, a
master module, and a blank module with screen for the eMix
software and joysticks. Each channel strip includes a multiformat
moving fader, 8 touch-sensitive knobs for EQ, filters,
compressor, expander/gate, aux, pan, and TDM, VST, and Audio
Units DAW plug-in control. The high-resolution screens
show multi-format metering, track info and routing display.
New Digital Processing Cards
The new expandable SC264D system computer provides DSP
channels each with EQ and dynamics processing, delay, and
surround panning to multi-format mix, group and aux busses.
EUCON Hybrid
What elevates S5 Fusion above other mixing systems is
EUCON Hybrid. EUCON is a control protocol developed by
Avid which allows high-speed Ethernet control of any
application. Apple’s Logic Pro, Merging’s Pyramix, Steinberg’s
Nuendo, MOTU’s Digital Performer and Apogee’s Maestro all
directly support EUCON for the ultimate in control integration.
EUCON also supports control of applications such as Pro Tools
and Final Cut Pro.
eMix
Operations such as system setup, file management, patching,
and diagnostics are managed by a program called eMix
which runs with a screen and keyboard, usually situated next
to the console. PatchNet, a powerful digital patching system
that handles patching for all the console’s inputs and outputs,
replaces a traditional patchbay with a system that can store
and recall every single patch that is made.
I/O
The S5 Fusion comes with 4 MADI inputs and outs, expandable
to 8 MADI ins and outs by adding an extra DSP cards.
A Avid MA703 MADI converter for monitors is included
using up one of the MADI outputs.
