Elastic Audio : Elastic Audio Plug-Ins
Elastic Audio Plug-In Window Controls
Polyphonic Plug-In
Rhythmic Plug-In
Monophonic Plug-In
Varispeed Plug-In
X-Form Plug-In (Rendered Only)
Pro Tools provides several algorithms for real-time and rendered track-based Elastic Audio processing. The selected Elastic Audio plug-in determines how the audio is processed. Each plug-in uses different algorithms for Elastic Audio processing. Different algorithms are better suited to different types of audio. Select the plug-in whose algorithm is appropriate to the material on the track you want to process.
Elastic Audio plug-ins have their own selector that is only available in the Edit window. You cannot insert Elastic Audio plug-ins on track inserts.
Elastic Audio plug-ins provide few to no adjustable parameters. The adjustable controls, if any, are available in the Elastic Audio Plug-In window. Elastic Audio plug-in parameters cannot be automated.
To open an Elastic Audio Plug-In window:
*Click the Elastic Audio Plug-In button.
Elastic Audio plug-in button
