EQ III : 7-Band EQ III
7-Band EQ III
7-Band EQ III High Pass/Low Notch
7-Band EQ III Low Pass/High Notch
7-Band EQ III Low Shelf/Low Peak
7-Band EQ III Low Mid Peak
7-Band EQ III Mid Peak
7-Band EQ III High Mid Peak
7-Band EQ III High Shelf/High Peak
Frequency Graph Display
The 7-Band EQ has the following available bands: High Pass/Low Notch, Low Pass/High Notch, Low Shelf/Low Peak, Low Mid Peak, Mid Peak, High Mid Peak, and High Shelf/High Peak.
All seven bands are available for simultaneous use. In the factory default setting, the High Pass/Low Notch and Low Pass/High Notch bands are out of circuit, the Low Shelf and High Shelf bands are selected and in circuit, and the Low Mid Peak, Mid Peak, High Mid Peak bands are in circuit.
7-Band EQ
