Workspace : Elastic Audio Files in the Workspace : Calculating Elastic Audio Analysis
To calculate Elastic Audio analysis:
1. In a Workspace browser, select the files you want to analyze.
2. Do one of the following:
*Right-click one of the selected files and choose Calculate Elastic Analysis from the pop-up menu.
*Preview the file with the Audio Files Conform to Session Tempo option enabled.
Analyzed files in which a regular tempo was detected are updated as tick-based, display their duration in Bars|Beats, and display their native tempo in the Tempo column.
Analyzed files in which no tempo was detected remain sample-based. These files typically contain only a single transient (such as a snare hit) or they are longer files without a readily identifiable regular tempo (such as entire songs).
*On Mac, if you do not see the Elastic Audio Analysis icon or the duration does not change to tick-based during the preview process, check the permissions for the folder in the Mac Finder. You must have write access of the directory for this feature to work.
