Advanced Search on a Selected Item
To initiate an advanced search on a selected item in the Locations pane:
1. Do one of the following:
Click the Advanced Search button.
Press Command+Shift+F (Mac) or Control+Shift+F (Windows).
2. If it is enabled, disable the Search Checked option at the left of the Locations pane header by clicking it.
3. In the Locations pane, select the Volume, Catalog, Project, or Folder that you want to search.
4. Select the Column type.
5. Select the Search Criteria.
6. Click in the Search Text field and type text for the search.
7. Press Return (Mac) or Enter (Windows).
The search results are displayed in the Browser pane.
If you want to refine your search, click the Add Row button to add further constraints to the search. Repeat steps 4-6 for each row you add.
