Clearing Unwanted Clips
In the Clips List, you can select unwanted clips and then use the Clear command to remove them from the project. Whole-file clips can also be permanently removed from the hard drive on which they are stored.
The Clear command cannot be undone.
To find and remove unused clips in a project:
1. Do any of the following:
For MIDI clips, from the Clips List menu, choose
Select > Unused.
For audio clips, from the Clips List menu, choose Select, then choose
Unused,
Unused Except Whole Files, or
Offline.
2. After all unused clips are selected, choose Clear from the Clips List menu. The Clear Selected dialog opens.
3. In the Clear Selected dialog, select the Automatically select all unused clips option if you want to ensure that all unused clips, including whole file clips, are selected for deletion or removal. Any selections previously made in the Clips List are ignored.
4. Do one of the following:
Click
Remove to remove the unused clips from the project.
If clearing a whole-file audio clip and you want to permanently remove the audio file from your hard drive, click
Delete.
When deleting audio files for multiple clips, Pro Tools presents a warning dialog for each audio file.
