Playing Back Track Material : MIDI Beat Clock : Transmitting Beat Clock
To transmit MIDI Beat Clock:
1. Choose Setup > MIDI Beat Clock.
2. In the MIDI Beat Clock dialog, select the Enable MIDI Beat Clock option.
3. Select the devices you want to receive MIDI Beat Clock. If your MIDI interface does not support transmitting MIDI Beat Clock to separate ports, only the interface appears as a destination.
4. Enter the correct negative offset values (such as “–200” samples) for each port that is enabled for transmitting MIDI Beat Clock (see “Measuring Beat Clock Latency” on page 210).
5. Click OK.
