Automating Sends
Pro Tools provides automation of send level, send mute, and send pan (for stereo and multichannel sends only). This makes it easy to control effect levels and placement during mixdown with great precision.
Send level and mute can also be configured to follow groups.
To automate a send level, mute or pan:
1. In the Automation window, make sure the automation type is write-enabled (send level, send mute, send pan).
2. In the Mix or Edit window, set the Automation mode for each track containing sends you want to automate. For each track, click the Automation Mode selector and set the Automation mode. For the initial automation pass, choose Write mode.
3. To display send controls, Click the send button to open the Send window.
4. Start playback to begin writing automation.
5. Move the controls you want to automate.
6. When you have finished, stop playback.
