Basic Mixing : Dither : Dither in Pro Tools | First
There are several ways dither can be used in Pro Tools | First. Each has a specific application within the various operations that could benefit from using dither.
• Dither Plug-Ins for Mixdown
Whenever you are mixing down or bouncing to disk and your destination bit depth is lower than 32-bit float, insert a dither plug-in on a Master Fader that controls the output mix.
For important information on using dither when mixing down or exporting the audio mix, see “Using Dither” on page 812.
*For more information on Dither plug-ins, see the Audio Plug-Ins Guide.
• Dither on Export
When you export audio to a lower bit depth, a preset, noise-shaped dither is applied.
*For more information about the application of dither on export, see “Exporting Audio” on page 182.
