Pro Tools | First Concepts : Pro Tools | First Projects : Signal Routing : Signal Routing Options
Signal routing options include the following:
• Track Input and Output (I/O) Controls
The most basic type of signal routing is track input and output. A track needs to have an assigned input path to record audio, and an assigned mapped output path in order to be audible through a hardware output. Signals can also be routed to or from other tracks in Pro Tools | First (or hardware inputs and outputs) using internal busses.
• Auxiliary Input and Master Fader Tracks
Auxiliary Inputs can be used as returns, submixers, and bus masters. Master Fader tracks are used as bus and output master level controls. Both Auxiliary Input and Master Fader tracks can have plug-in inserts.
• MIDI Tracks
MIDI tracks are generally used for routing MIDI from internal or external sources to external MIDI devices. MIDI data can also be routed to plug-ins on Auxiliary Inputs or Instrument tracks.
• Instrument Tracks
Instrument tracks are the primary way to route MIDI to an instrument plug-in and then route the plug-in’s sound to outputs, sends and busses, or other inserts. Instrument tracks can also be used to send MIDI to and monitor audio from external MIDI devices.
• Sends
Sends route audio from tracks to hardware outputs, or to internal busses that are in turn routed to other tracks within your project. MIDI and Master Fader tracks do not have sends.
• Plug-in Inserts
Plug-in processing occurs completely within your project. MIDI tracks do not have inserts.
• Instrument Plug-Ins
Instrument plug-ins are different from processing plug-ins in that they generate audio rather than process the audio signal from a track’s audio input or from hard disk.
Instrument plug-ins are played by MIDI.
• Paths
Paths are any routing option in Pro Tools | First, including internal or external inputs, outputs, busses, and inserts.
