Using the TCE Trim Tool in Spot Mode
In Spot mode, clicking with the TCE Trim tool in a clip opens the Spot dialog. You can specify the location you want the clip to start or end at, or the duration of the clip, and the clip is automatically compressed or expanded as specified.
To use the TCE Trim tool in Spot mode:
1. Set the Edit mode to Spot.
2. Click the Trim tool pop-up menu and select TCE.
3. Click the clip near its start or end point. The Spot dialog opens. Using any Time Scale, enter a new start or end time (or duration) for the clip, then click OK.
