Event Operations : Step Input Command : Step Input Controls : Step Input Options
Step Input Options
• Use Input Velocity
When selected, MIDI notes are recorded using the velocity that you play on your MIDI keyboard.
• Set Velocity To
When selected, MIDI notes are recorded with the velocity that you specify in the Velocity field. This value can be set with the Velocity slider.
• Enable Numeric Keypad Shortcuts
When selected, Step Input options can be selected from the numeric keypad. “Numeric Keypad Shortcuts for Step Input” on page 628
