Selecting and Splitting Notes
To select and split notes:
1. Do one of the following:
With the Grabber or Selector tool, select the range of MIDI notes that contains the notes.
To affect all the MIDI notes on a track, click in the track with the Selector tool, so that it contains a flashing edit cursor.
2. Choose Event > Event Operations > Select/Split Notes.
3. Configure the Pitch Criteria.
4. Configure the Other Criteria (Velocity, Duration, and Position).
5. Enable the Select or Split option.
6. From the Split Notes pop-up menu, select Copy or Cut.
7. If splitting notes, select the Copy or Cut to destination.
8. If splitting notes, enable the Include All Continuous MIDI Data option. Enabling this option includes all controller data associated with the split notes in newly created tracks. Leave this option deselected to split only note data to new tracks.
9. Click Apply.
Any Real-Time Properties associated with the track or clips are copied to new tracks created by Select/Split Notes.
