Event Operations : Select/Split Notes Command : Select/Split Notes Settings : Other Criteria
Other Criteria
• Velocity
Enable the Velocity option to specify a range of velocities for selecting or splitting notes. Enter minimum and maximum velocities.
• Duration
Enable the Duration option to specify a range of durations (in beats and ticks) for selecting or splitting notes. Enter minimum and maximum durations.
• Position
Enable the Position option to select or split all notes that fall into a range of relative beat and tick locations within each bar. The minimum value determines the start of the range, the maximum value sets the end of the range.
