Event Operations : Change Duration : Change Duration Settings : Remove Overlap
Remove Overlap
The Remove Overlap option removes any note overlap for all notes of the same pitch. This command is different from Legato in that non-overlapping notes of the same or different pitches remain unchanged. To create a gap between previously overlapping notes, enter the gap in beats and ticks.
