Elastic Audio : Elastic Properties
Elastic Properties
Each clip on an Elastic Audio-enabled track has specific Elastic Audio properties (such as tempo, meter, TCE factor, Input Gain, and Pitch Shift).
The Elastic Properties window lets you view and change the properties for selected clips. For example, you can reduce the Input Gain for Elastic Audio processing to avoid clipping that can occur during processing.
From the Elastic Properties window, you can also filter Event markers for Elastic Audio clips on tick-based tracks. Filtering Event markers can result in better quality Elastic Audio processing of material with ambiguous transients.
To view the Elastic Properties for a clip:
1. Select a clip on an Elastic Audio-enabled track. The track can be either sample- or tick-based.
2. Do one of the following:
*Choose Clip > Elastic Properties.
*Right-click the clip and choose Elastic Properties.
*Press Option+5 (Mac) or Alt+5 (Windows) on the numeric keypad to open the Elastic Properties window.
